Reply To: Problem whith my program in interface page
Home › Forums › Problems and solutions in GDL › Graphical UI and parameters list › Problem whith my program in interface page › Reply To: Problem whith my program in interface page
#1599
Csilla Mai
Member
Hi Tonio,
Apologies for the previous attachment (for version 20).
In this new attachment you can find two kinds of solutions in the Array_inCallerObject folder and Array_inMacro file. In the latter case you do not have to set the material list arrays in all of your objects, but the parameter would disappear if the user sets the Material parameter in the caller object to 1. Therefore the ‘All parameter’ list should not be hidden, because it could make the parameter invisible for the user, once its value is set to 1. The other solution would not hide the parameter from the user by setting its value to 1, but the materials have to be listed in the caller object.
Csilla Mai
