Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Numbered objects with an identifier number. › Reply To: Numbered objects with an identifier number.
October 11, 2015 at 15:33
#1699
There is no solution in GDL for that: an object does not know anything about previously placed objects.
I think you should use the ID instead, which makes this increasing for you automatically, and you can check the ID from your scripts and draw that from 2d script.
