Home › Forums › Problems and solutions in GDL › Library migration › Migrating multiple objects forward into a single object › Reply To: Migrating multiple objects forward into a single object
October 12, 2015 at 20:23
#1725
For the first view: you shouldn’t comment the following lines:
! actualGUID = "29BC0A02-02ED-4536-A043-ECE303A3FB31"
Delete the exclamation mark, as you need to set your migration ID to the ID of your new object. In my quick test file, it solved the problem.
