Home › Forums › Problems and solutions in GDL › 3D modelling › GDL switch to turn off SEO? › Reply To: GDL switch to turn off SEO?
October 20, 2015 at 15:07
#1773
Possible workarounds:
- create and place your object as a wall accessory, then you can “leave out” the doors and windows, so your object won’t override the openings.
- place blocks to your openings, cut your object with this blocks with SEO, and then then use SEO with the cut object and the wall
