Reply To: What is the proper replacement for GLOB_​​​CONTEXT=1?
Home › Forums › Problems and solutions in GDL › Informations from the environment › What is the proper replacement for GLOB_​CONTEXT=1? › Reply To: What is the proper replacement for GLOB_​​CONTEXT=1?
#1780
I think that a separate context for the editor is not needed: in your example the “flag” parameter should be deleted. It is a much better solution to use the source format of library parts, and modify parameter defaults with the lp_xmlconverter, during the library compilation. In this case, you should force your category parameters default to an empty string with a replacement definition file, and check that value instead of having one more parameter for checking if the default is set.
