Home Forums Problems and solutions in GDL Library build system LP XML Converter Check Library Error Messages Reply To: LP XML Converter Check Library Error Messages
#1812
6ACDA889-69B2-4EC5-936C-CB1DA7032A92 is the main ID of the opening subtype. Did you add the proper built-in library as additional lib? In the libdevtoolkit package it is included to the build system…
