Home › Forums › Problems and solutions in GDL › Library build system › LP XML Converter Check Library Error Messages › Reply To: LP XML Converter Check Library Error Messages
#1820
I checked the libdevtoolkit v17, and there are all the subtypes in Sources/ACPM/ArchiCAD/RINT folder. You can compile this with Sources/ArchiCADLibrary/Make/MakeLibrary.pl script, and then use the binaries from the compiled ACPM folder as an additional lib.
