Reply To: Use drawing scale on layouts to Set Scale bar
Home Forums Problems and solutions in GDL Informations from the environment Use drawing scale on layouts to Set Scale bar Reply To: Use drawing scale on layouts to Set Scale bar
#18477
shaun coomber
Yes, we went through the same thought process – objects on the layout can’t see the scale of the drawings, and ARCHICAD only fills out autotext after placement so the GDL doesn’t see it. We ended up having separate positioning options for the scale bar within the title object, to position it relative to the drawing or to the layout itself. There still has to be a drawing on the layout, but the scale bar doesn’t have to be placed with the title, and the scale bar doesn’t necessarily move with the drawing.
