Home › Forums › Problems and solutions in GDL › 3D modelling › Aligning REVOLVE and BPRISM geometry › Reply To: Aligning REVOLVE and BPRISM geometry
		December 16, 2019 at 16:43
		#18491
	The REVOLVE{2} will always close the polygon (first to last point).
So of you want the surface back to the rotation axis you need to add a point with a 0 (zero) y-position.i.e.
<code class="hljs">PUT 0, 0.000, 2, shellSurface, 0, 0.5*diskWidth, 2, shellSurface, 0.5*diskHeight, 0.5*diskWidth + lipWidth, 2, shellSurface, diskHeight, 0.5*diskWidth, 2, shellSurface, diskHeight, 0.000, 2, shellSurface ADDZ 1 ROTY -90 REVOLVE{2} NSP/4, 0, 360, 4*1 + 8*1 + 16*1 + 32*1 + 64*0 + 128*0 + 256*0, shellSurface, GET(NSP) DEL 2Barry.
That worked perfectly, thank you Barry
