Reply To: Use buttons to select variable from a parameter
Home Forums Problems and solutions in GDL Graphical UI and parameters list Use buttons to select variable from a parameter Reply To: Use buttons to select variable from a parameter
#18652
Method 5 is a simple pushbutton, it only has on/off states.
With method 4 or 6 more states are available, but you have to draw the pictures on the buttons, just giving a string is not possible.
All options go in the same statement:
ui_infield{3} "existing", 0, 100, 100, 20,
	4, "", 0, 0,
	0, 0, 0, 0,
	0, "one", 1,
	0, "two", 2,
	0, "three", 3
And setting the options in parameter script is also necessary:
values "existing" 1,2,3
To use strings code many boolean buttons, which are conected in the parameter script and only one of them can be selected.
