Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Are there parameters for Monolith Stair Structure's surface/bmat? › Reply To: Are there parameters for Monolith Stair Structure's surface/bmat?
March 31, 2020 at 11:28
#18669
No, monolith structure isn’t a library part, so you don’t have information about it’s parameters in a label.
It’s properties are accessible, try the “Classification and Properties Label” for a demonstration.
It is possible to define a property whose value is an expression, and this expression can be the building material of the object. Though currently stair structure surfaces aren’t available in a property expression.
