Reply To: APPLICATION_​​​QUERY slows down moveable hotspots
Home Forums Problems and solutions in GDL Informations from the environment APPLICATION_​QUERY slows down moveable hotspots Reply To: APPLICATION_​​QUERY slows down moveable hotspots
#18672
Hm, what are you doing with the result? If it is stored as an array in a parameter, you might still use it GLOB_FEEDBACK_MODE.
What ArchiCADLibrary does is it calls the request in ARCHICAD_Library_Master (in subtype “Library Master”), which is only run when the library is loaded. The results are set with VALUES to a parameter. All libparts that have the same parameter get their values from the Library Master.
