Home › Forums › Problems and solutions in GDL › Informations from the environment › Back referenced layouts › Reply To: Back referenced layouts
It turns out it wasn’t designed to be used by library parts.
When AC_BackReferenceGUIDList[1] is used in a special autotext – “
That is the only possible use of it, single GUID’s can’t be written as autotext.
The user can select the referenced drawings after clicking Back Reference button in the drawing settings dialog on the Title tab. Theoretically you could filter AC_BackReferenceGUIDList in the parameter script, but that would interfere with this dialog.
