Reply To: Use fill from surface in 2D-symbol?
Home Forums General discussions Use fill from surface in 2D-symbol? Reply To: Use fill from surface in 2D-symbol?
#18709
David Shorter44
Mats
I have to confess I cheated.
I drew a fill block on the floor plan and saved it as a object.
I created it at the origin to a known size (600×600) using a fill geometry ‘linked to the fill origin.
I then selected it and saved it as an object, opened the object and edited the 2D script.
I can go into more detail if that would help but I’m not sure how much you know.
Let me know if you need more guidance.
Hope this helps
ArchiCAD 4.1-22
MacBook RetinaDisplay
16Gb RAM 500Gb SSD
BIMXdocs
