Reply To: Parameter Variable Name
Home › Forums › General discussions › Parameter Variable Name › Reply To: Parameter Variable Name
#18740
You can use …
n = REQUEST ("ASSOCLP_PARVALUE", expr, name_or_index, type, flags, dim1, dim2, p_values)
Or
n = REQUEST ("ASSOCLP_PARVALUE_WITH_DESCRIPTION", expr, name_or_index, type, flags, dim1, dim2, p_values_and_descriptions)
But the problem is you need to know the parameter name or index you want before you can request it – which defeats the purpose of requesting it?
To label all parameters of an object you might want to look at this …
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=33434&p=174988&hilit=label+parameters+ASSOCLP_PARVALUE#p175031
