Home › Forums › Problems and solutions in GDL › Parameter connections › Profile name in Master Script › Reply To: Profile name in Master Script
May 11, 2020 at 09:37
#18784
Assuming with this naming scheme the surfaces are specific to the library parts: create the surfaces from the library parts or a MASTER_GDL. You can then use a string type parameter to select the surface, and transform the name into another string.
