Reply To: Properties not working with multiple choice Option Set
Home › Forums › Problems and solutions in GDL › Informations from the environment › Properties not working with multiple choice Option Set › Reply To: Properties not working with multiple choice Option Set
#18804
Lukas I can’t reproduce that in AC23.
James’ problem is still there, the cause is in the example:
REQUEST “Property_Value_Of_Parent” returns an empty array when no options are selected for the option set, overwriting _dim1 causes “Index value greater than array dimension”. This should be an error message but is only shown with “Check Library Parts for Warnings” selected.
