Reply To: Remove edge of picture objects
Home › Forums › Problems and solutions in GDL › Object design › Remove edge of picture objects › Reply To: Remove edge of picture objects
#1927
vistasp mehta
James, is this in OpenGL? If so, you will have to turn off contours.
If you want to render it correctly in Cine Render, you’ll have to use the Physical engine.
Have a look at this thread on AC-Talk.
https://archicad-talk.graphisoft.com/viewtopic.php?p=233352
= v i s t a s p =
bT Square Peg
https://archicadstuff.blogspot.com
https://www.btsquarepeg.com
| 18 INT | Win7 x64 |
