Home › Forums › Problems and solutions in GDL › Informations from the environment › WALL_SKINS_BMAT_NAMES › Reply To: WALL_SKINS_BMAT_NAMES
December 2, 2015 at 20:33
#1961
Heimo Mooslechner
I have some problems with this parameter and the correct usage..
i wrote:
OFT = WALL_SKINS_NUMBER
i=1
for ii = 1 to oft
WSP[ii] = WALL_SKINS_PARAMS[ii][1] !Schraffur
KernSTR = STR(WALL_SKINS_PARAMS[ii][6], 1,0)
Kern = WALL_SKINS_PARAMS[ii][6]
WSBN[ii]=WALL_SKINS_BMAT_NAMES[ii][1] !Baumaterial
add2 0.15,0.02
style links
t = REQUEST{2} ("Building_Material_info", WSBN[ii], "gs_bmat_surface", oberflaechen[ii]) !!S378
r = REQUEST ("Name_of_material", oberflaechen[ii], name[ii])
del 1
if ii = 1 then Aussenputz = oberflaechen[ii]
if ii = oft then Innenputz = oberflaechen[ii]
s=request("Name_of_fill",WALL_SKINS_PARAMS[ii][1],Schichtnamen[ii])
!Schichtnamen[ii]=WSBN[ii]
Schichtdicken[ii]=WALL_SKINS_PARAMS[ii][2] !Dicke
if KernSTR="3" then
WoKern = ii
else
Gesamtdicke = Gesamtdicke + Schichtdicken[ss]
add2 0, -0.015
next ii
del oft-1
for ss = 1 to WoKern-1
Dickensumme = Dickensumme + Schichtdicken[ss]
next ss
in the 2D-Script – i got correct answers from it.
there i wrote:
for ii = 1 to oft
add2 0, 0.05
text2 0,0,oberflaechen[ii]
Text2 0.2,0, Aussenputz !! nur als Test - schreibt brav 18 hin
next ii
del oft-1
BUT – in the 3D-Code – i got Just 0 when i tried the same – and there i would need it so badly…
i wrote in 3D:
DEFINE STYLE test "Arial", 10, 1, 0
style test
for ii = 1 to oft
addy -0.012
addz 0.1
text 0, 0,oberflaechen[ii] - !!nur als Test - da schreibt er gar nichts hin
TEXT 0.01, 0, Aussenputz !! sollte überall 18 stehen - aber macht im 3D 0 draus
del 1
next ii
del oft
Why is it not functional in 3D?
I personal would need it for self made wall-openings with much more editable hotspots than are used in the normal Archicad-library.. for a much better user-experience..
Teacher in HTL-Salzburg
AC5-19, Win and Mac
GDL hobby developer
