Home › Forums › About this site › Ideas about GDL Center › Comprehensive section on globals and requests › Reply To: Comprehensive section on globals and requests
December 9, 2015 at 18:50
#2008
You can use the font names from our master file, but there can be problems:
- you can’t use those objects without the standard ARCHICAD library
- if we change our master file, then there is no guarantee that your object will work with an upcoming version
If you decide to use our file, you don’t need to script anything, just add one of the font parameters from the master file to your object, and it will work.
