Home › Forums › Problems and solutions in GDL › Doors and windows › How to insert a new Tab on default ArchiCad windows/Doors › Reply To: How to insert a new Tab on default ArchiCad windows/Doors
Doug,
not sure if I understand right.. the All Parameters List option is not really removed, we just started to use the hideparameter command (with the all parameter) to omit it in most of GRAPHISOFT’s objects for better-looking interfaces. This is optional. If you create objects only using the All Parameters list, that’s fine. If you want to have an UI along the All Parameters list, that is also possible (without doing anything special). The special thing is only needed to hide the list (hideparameter command).
If you need further info, give me an example or a more detailed specification. Thanks.
Product Manager
