Reply To: GDL door and window parameters related to zones
Home › Forums › General discussions › GDL door and window parameters related to zones › Reply To: GDL door and window parameters related to zones
#2194
David Shorter44
Hi
19 INT
With the door this parameter can be automated using the “Location as” parameter.
You seem to have missed the point here. With the Door the user can automatically pull the name or number (using the “Location as” parameter) from the door to which it is attached. This is not possible with the window BUT it should be. I know the user can enter the value manually but this will only guarantee an error at some point. Automating the association of the window (and door) to its associated zone is an essential requirement. The keywords here are intelligent automation.
Hope this helps
ArchiCAD 4.1-22
MacBook RetinaDisplay
16Gb RAM 500Gb SSD
BIMXdocs
