Reply To: Request Override Surfaces
Home › Forums › Problems and solutions in GDL › Object design › Request Override Surfaces › Reply To: Request Override Surfaces
#2204
Csilla Mai
Member
Hi Daniel,
The surface indices of the ARCHICAD elements are available through the Global Variables. To get the name of the material you can use the “Name_of_material” request. For example displaying the material names of a slab element in a label object in 2D:
_matTop 	= ""
_matBottom 	= ""
_matEdge 	= ""
r = request ("Name_of_material", SLAB_MAT_TOP, _matTop)
r = request ("Name_of_material", SLAB_MAT_BOTT, _matBottom)
r = request ("Name_of_material", SLAB_MAT_EDGE, _matEdge)
text2 0, -1, _matTop
text2 0, 0, _matBottom
text2 0, 1, _matEdge
Is this solution the one that you need? Could you please explain that what would you like to use the material names for?
Csilla Mai
