Reply To: Is there a way to query all Library Part names in the loaded Libraries?
Home Forums Problems and solutions in GDL Informations from the environment Is there a way to query all Library Part names in the loaded Libraries? Reply To: Is there a way to query all Library Part names in the loaded Libraries?
#2265
There will be failures in case of library updates or migrating to new versions – when parametrization of a libpart can change. Pla saving can be wrong too – you won’t be able to use your pla in an upcoming version if the called library part is migrated.
If you need one of our placeable library parts as a macro, then you should open it with the editor and save as a macro (not placeable) with a new name. Then you can use it in your libraries.
