Home › Forums › Problems and solutions in GDL › Informations from the environment › Is there a way to query all Library Part names in the loaded Libraries? › Reply To: Is there a way to query all Library Part names in the loaded Libraries?
We don’t rarely use the Graphisoft libraries as we have our own custom library that suits our needs better.
I certainly would not call objects/macros in your libraries as I am aware they can change without me knowing what has changed.
I am just getting into migrating objects this last week actually and have spotted the possible problem of migrating objects called by other objects.
But I am hoping that if I keep the original names then the call will still work.
I am aware that migrating an object with a new name is probably a more logical way to keep track of them but I am hoping keeping the same name solves the ‘CALL’ problem.
Obviously there will be problems if parameters have changed in the called object but that would apply if calling a place-able object or a macro. So I just have to be careful to update any called parameters in the master objects as well.
The biggest problem I am having at the moment is remembering/finding all the objects that call other objects/macros that I want to amend/migrate.
