Reply To: Is there a way to query all Library Part names in the loaded Libraries?
Home Forums Problems and solutions in GDL Informations from the environment Is there a way to query all Library Part names in the loaded Libraries? Reply To: Is there a way to query all Library Part names in the loaded Libraries?
#2268
Tony Krepler
Thanks Gergely very true, should not have done that. One of the “quick and dirty solutions, that worked beautifully. Should never use Graphisoft parts πŸ˜‰ If it makes things any better, I always felt bad about it. πŸ˜‰
The fact is, that if you take the chair, you need to re-save all it’s macros as well, and I was putting it off.
On the other hand, I was always wondering how can ArchiCAD remember the ID of the macro, as all you can see is the name in the script.
I know it might be a different topic, but how do you resolve a situation, where you have duplicate macros, without re-saving them and going through every script that is calling them?
Thanks,
Tony Krepler
fjmt
