Home › Forums › Problems and solutions in GDL › Library build system › LP XML Converter Check Library Error Messages › Reply To: LP XML Converter Check Library Error Messages
February 25, 2016 at 06:33
#2294
Tony Krepler
hi Gergely,
When converting XMLs to GSM, I have got an error message at several Library Parts:
“…20: error: XML validation failed; no declaration found for element ‘ContVis'”
The number in the front varies – so it might not have a particular significance.
The XML giving the error message, were not converted back to GSM. I was a bit surprised as I have just converted the Library to XMLs shortly before to check something.
Could you please help me what to check? Thanks a lot.
Kind regards,
Tony Krepler
fjmt
