Home › Forums › Problems and solutions in GDL › Library build system › LP XML Converter Check Library Error Messages › Reply To: LP XML Converter Check Library Error Messages
#2318
Tony Krepler
Thanks a lot Gergely. I have finally got to test it.
It all went well, except for one odd error message – but I guess it is not related to the previous problem:
122795: error: XML validation failed; value ‘-1’ must be greater than or equal to minInclusive facet value ‘0’
I suppose something might wrong at our end – could you please help, what that would be? Thanks again.
Cheers,
Tony
