Home › Forums › Problems and solutions in GDL › Parameter connections › Newparameter › Reply To: Newparameter
April 19, 2016 at 16:25
#2421
It works for me (maybe you should check with a bigger gap between your blocks, as they are overlapping in your sample…), but you should modify your script a bit:
!MASTER
dim intparam[5]
intparam[1] = 1
intparam[2] = 2
intparam[3] = 3
intparam[4] = 4
intparam[5] = 5
dim descparam[5]
descparam[1] = 'opt1'
descparam[2] = 'opt2'
descparam[3] = 'opt3'
descparam[4] = 'opt4'
descparam[5] = 'opt5'
!Paramscript
for k=1 to 5
values{2} "a"+str(k,1,0) intparam, descparam
next k
You should avoid using “mixed” type arrays.
