Home › Forums › Problems and solutions in GDL › Parameter connections › Newparameter › Reply To: Newparameter
May 18, 2016 at 14:48
#2477
There are multiple problems with the script above:
– the 2 arrays in the master should run to the 4th index (you have double 3)
– values{2} only works for integer types (“A” is length type by default)
– loose the array brackets in the values{2} command definition
– the ASSOCLP_PARVALUE_WITH_DESCRIPTION request returns pairs of value-description of the requested parameter, so info1 should be an array type of variable (otherwise it will only contain the first returned value only, without description string)
You can do this:
dim info1[]
n = REQUEST("ASSOCLP_PARVALUE_WITH_DESCRIPTION", "parammparamm", DUMMY_name_index, DUMMY_type, DUMMY_flags, d, dd, info1)
if vardim1(info1) > 0 then
for ii = 1 to vardim1(info1) step 2
text2 0, 0, info1[ii]
text2 1, 0, info1[ii+1]
next ii
