Reply To: Text, visible on the Floor Plan, not visible for Print OUT
Home Forums Problems and solutions in GDL Documentation elements, text handling Text, visible on the Floor Plan, not visible for Print OUT Reply To: Text, visible on the Floor Plan, not visible for Print OUT
#2489
Hi Daniel,
I think it is not possible to create an object like that with simple 2d scripting. For a workaround, you can do it with a lib based MVO, where you can set up a parameter for that, reach it from your objects and create different views for editing and printing/exporting.
Or you can do it without GDL: put these object to a new layer, and simply turn it off before printing/exporting.
