Reply To: Updating parameters from 3D script
Home Forums Problems and solutions in GDL Parameter connections Updating parameters from 3D script Reply To: Updating parameters from 3D script
#2503
Parameters can only be updated from parameter script (or the master script when it is running as paramscript). In a situation like this, the less painful solution is to put the calculations to the master – if you can’t avoid to store the number of seats in a parameter.
