Reply To: Point inside a polygon using Polygon Operations Macro
Home › Forums › Problems and solutions in GDL › GDL add-ons › Point inside a polygon using Polygon Operations Macro › Reply To: Point inside a polygon using Polygon Operations Macro
#2593
Hi SimPey,
The macro you are calling returns “On edge” status for points that lie on the line of the edge, even if they are outside the start-end segment. You could check in your code if that is the case.
The official library doesn’t use this macro with the OPERATION_POINT_INSIDE_POLYGON parameter.
