Reply To: How i can set WIDO_​​​SILL_​​​HEIGHT ?
Home Forums Problems and solutions in GDL Doors and windows How i can set WIDO_​SILL_​HEIGHT ? Reply To: How i can set WIDO_​​SILL_​​HEIGHT ?
#2740
I’m still not sure I am on the right track but you could place your door and manually set the sill height to what you want in relation to the wall base or storey level.
But if you want to automatically raise the height based on the door type then I would just add something like this to your 3D script …
if door_type = "type A" then
ADDy 0.005
if door_type = "type B" then
ADDy 0.007
if door_type = "type C" then
ADDy 0.009
Then when you place the door make sure you place it with the sill set to zero height above the wall base (or storey).
