Home › Forums › Problems and solutions in GDL › Doors and windows › Area Calculation and Window Dimensions › Reply To: Area Calculation and Window Dimensions
November 2, 2016 at 11:52
#2825
Joachim,
As I know there is no additional documentation for that… It is allowed to use your own parameters, so you can use the paramscript to make calculations and then use the calculated value in that short field. Variables can not be used for that purpose, you can only use the objecst own parameters and globals.
