Reply To: Array Parameter
Home › Forums › General discussions › Array Parameter › Reply To: Array Parameter
#2836
Try it with the following paramscript, where “size1” and “size2” are the array size parameters and “myArray” is the array with changeable size:
values "size1" range [1,)
values "size2" range [1,)
if GLOB_MODPAR_NAME = "size1" or GLOB_MODPAR_NAME = "size2" then
                dim _tempArray [][]
                _tempArray = myArray
                dim myArray [][]
                for ii = 1 to size1
                                for jj = 1 to size2
                                                if ii > vardim1(_tempArray) or jj > vardim2 (_tempArray) then
        _value = 0
                                                else
        _value = _tempArray[ii][jj]
                                                myArray[ii][jj] = _value
                                next jj
                next ii
                parameters myArray = myArray
