Reply To: Use Properties from Property Manager
Home › Forums › Problems and solutions in GDL › Lists and schedules › Use Properties from Property Manager › Reply To: Use Properties from Property Manager
#2889
This request can not be used in parameter script, check it in the documentation please: “Expression returns 0 and contains dummy return values (emtpy string or 0) if used in parameter script, causing additional warning.”
Instead of this, you can use it in the ui script, and use the returned values in a custom popup infield, as it is written here: https://gdl.graphisoft.com/tips-and-tricks/display-properties-with-labels/
