Reply To: Use Properties from Property Manager
Home › Forums › Problems and solutions in GDL › Lists and schedules › Use Properties from Property Manager › Reply To: Use Properties from Property Manager
#2894
Enabling these request in parameter scripts would cause problems: if you can reach properties in parameter script, then you can store them as parameter values. After placing an object and storing it’s parameters, you can easily change the properties – so the stored information will be outdated and can cause problems in lists and schedules, as there is no way to force parameter script run on all placed library parts in a whole project. Running all instances parameter script would be extremely slow in huge project and could affect the model appearance, which means a problem in background processing. And, if there would be a function to do that, you can’t do that in teamwork without reserving all library parts to make changes on their parameters…
