Home › Forums › Problems and solutions in GDL › Object design › Macros and hotspot2 › Reply To: Macros and hotspot2
		January 27, 2017 at 16:19
		#2955
	This worked but I thought that it was possible to put them out with a fixed value.
But it is not possible to lay them with a fixed value as the item is in the dimension I want to start with and then use hotspots to adjust it to a different value to the desired length.
If possible how I can do it?
Laurits Frydenberg
Technical drawing
