Reply To: Macros and hotspot2
Home Forums Problems and solutions in GDL Object design Macros and hotspot2 Reply To: Macros and hotspot2
#2960
Moreso, you can try to use the VALUES command to set a discrete value-list for you parameter.
For example: “B” only should be working at 500, 200, 350, then:
values "B" 500, 200, 350
If you add a hotspot for “B” editing, it will jump to the previously set values only.
