Reply To: Centerpoint in simpel 2D symbol
Home Forums Problems and solutions in GDL Object design Centerpoint in simpel 2D symbol Reply To: Centerpoint in simpel 2D symbol
#2993
David Maudlin
Anders:
Since you have now defined all the points using the Line2 command, you can use these same points with one of the Poly2_ commands (which one you choose depends on the amount of control you want over the fill). The Poly2_ command can draw both the fill and its outline (look at the frame_fill options) so you will be able to remove the Line2 commands when done.
David
David Maudlin / Architect
Washington, D.C.
AC 22 - Mac OS
