Reply To: How to get coordinates of the section/elevation story line?
Home Forums Problems and solutions in GDL Parameter connections How to get coordinates of the section/elevation story line? Reply To: How to get coordinates of the section/elevation story line?
#3246
That should be the correct shortcut (works for me).
Make sure you are only selecting the name inside the quotes and not the quotes as well.
If the shortcut doesn’t work you can use the ‘Edit GDL Library Parts’ toolbar.
