Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Stop label mirroring on Hotlinked Module › Reply To: Stop label mirroring on Hotlinked Module
August 8, 2017 at 07:58
#3452
Hi Kristian,
You can use RSS to check the forum answers, use this url: http://gdl.graphisoft.com/forums/feed.
As I know, there is no solution in GDL to check the wall’s refline’s side in the current version – so the “flip” option is a known workaround, which is far from perfect in some situations…
