Reply To: Forward Migration
Home › Forums › Problems and solutions in GDL › Library migration › Forward Migration › Reply To: Forward Migration
#3484
As far as I can see that should work – that is basically the script I use.
But as mentioned in Archicad-talk …
However make sure you have the old GUID in the ‘Migration’ list – that is a different button to the ‘Forward Migration’ script. Do not have the new GUID in that list.
Also make sure you do not have the old object in you loaded libraries. If you do the swap will not happen.
