Reply To: append current value to the list with ui_​​​button
Home Forums Problems and solutions in GDL Graphical UI and parameters list append current value to the list with ui_​button Reply To: append current value to the list with ui_​​button
#3498
Maciek Bajor
Yes I think so too. Probably worth to mention common workaround – Create global variable var and then in parameter script write
parameters var = GLOB_MODPAR_NAME
than you can reference to var in Master and 2D. In case anybody wondered – because that is not intuitive at all.
