Reply To: Component Name Linked to a Variable
Home Forums Problems and solutions in GDL Lists and schedules Component Name Linked to a Variable Reply To: Component Name Linked to a Variable
#3642
Example code in parameter script:
_formatStr = “”
rrr = REQUEST (“Window_door_dimension”, “”, _formatStr)
stPanelSizesForList = STR{2}(_formatStr, A) + ” x ” + STR{2}(_formatStr, B)
parameters stPanelSizesForList = stPanelSizesForList
lock “stPanelSizesForList”
This example formats the “A” and “B” length values according to Project Preferences/Dimensions/Door, Window and Skylight Dimensions settings in ARCHICAD.
“stPanelSizesForList” should be a new, string type parameter in your objects.
