Reply To: Force Refresh of Objects using LIBRARYGLOBAL
Home Forums Problems and solutions in GDL Informations from the environment Force Refresh of Objects using LIBRARYGLOBAL Reply To: Force Refresh of Objects using LIBRARYGLOBAL
#3664
Debugging MVO returned values: we usually use text output commands (text2), to check on it, or you can try PRINTing it into the report window.
Never should it be stored in a parameter.
Glad you could handle the issue.
