Home › Forums › Problems and solutions in GDL › GDL add-ons › XML addon & script location › Reply To: XML addon & script location
November 13, 2017 at 12:06
#3669
Parameter changes from interactive schedule will initiate a paramscript run in the selected object(s).
The best way of reading an xml file depends on many things:
– how often the source will change,
– will it be a part of the library, and loaded together with the objects,
– and the purpose of using external data…
You should tell me more about the details, to be able to suggest a solution.
