Reply To: Return parameters without a parameter
Home Forums Problems and solutions in GDL Parameter connections Return parameters without a parameter Reply To: Return parameters without a parameter
#3791
The returned parameters is just a “simple value list” in the specified order – it is not really “parameters”, just variables in the scripts.
You need to declare the list of values to be returned at the end of the called macro’s script, like this:
end value1, value2, value3
Then in the caller object, you need to specify the variables to where you want to fill in these values:
call “samplemacro” parameters …..
returned_parameters variable_receives_value1, variable_receives_value2, variable_receives_value3
I hope it helps, if not, please upload a sample which you can’t solve. (Upload in zip please, as gsm files are forbidden by the hosting service provider of this site.)
