Reply To: Parameter values with array (dim)
Home Forums Problems and solutions in GDL Parameter connections Parameter values with array (dim) Reply To: Parameter values with array (dim)
#3797
Csilla Mai
Hi Pavel,
The values command in parameterscript only defines a set of values for the actual parameter, it does not change the parameter’s value itself.
For changing the parameter’s value, use the parameters command:
parameters nTypZdroje = aTypZdroje
Csilla Mai
